DanteSS3 Posted September 26, 2006 Report Share Posted September 26, 2006 I was adding music to my Sony Walkman NW-E507 a few mins ago and when i finished i went to go and listen to it.I found that the number of songs hadn't increased and that some of my songs didn't show up where they were suppose to show up.They are still on the walkman, as SonicStage shows that they are on it, and the memory space left has decreased from before i added the new songs.Aybody able to help? Quote Link to comment Share on other sites More sharing options...
0 deviatorz Posted September 27, 2006 Report Share Posted September 27, 2006 Try reseting the player, and plugging the player in a couple of time (to the computer). Are your mp3 or w/e music files you uploaded have a constant bitrate? I know for one thing and it's that the player can't play music files that don't have a constant bitrate, well at least on mine it can't. If worst comes to worst, delete the files you uploaded and reupload them to your player. Hope this helps. Quote Link to comment Share on other sites More sharing options...
0 DanteSS3 Posted September 27, 2006 Author Report Share Posted September 27, 2006 YAY Thank you, resetting it worked.Since i've changed to ATARC3 66kbps the walkman seems a little unstable (Maybe because it has over 350 songs now)Thank you again Quote Link to comment Share on other sites More sharing options...
0 Dil Posted October 10, 2006 Report Share Posted October 10, 2006 Not really, I've the same player, uploaded 699 songs in ATRAC3 Format, and all of them played smooth and normal, maybe you should upgrade your SonicStage! By the way, does the metal part of your player. tends to get scratch and seems to "corrode" easily? I'm beginning to get black stains on it, in just eight months... Quote Link to comment Share on other sites More sharing options...
0 DanteSS3 Posted October 19, 2006 Author Report Share Posted October 19, 2006 Ehh i don't think so...but i'm not sure about what bit your talking about What i have noticed is where the mirror finish joins up to the silver finish, there seems to be a ragged ness to it which i don't remember when i first bought it, could be dirt but i'm not sure.Other than that it is working fine now with about 400 songs Quote Link to comment Share on other sites More sharing options...
DanteSS3
4 answers to this question
