Ana Nunes Posted March 9, 2021 Report Share Posted March 9, 2021 Hello, I would like to know if it is possible to recover erased files from my MiniDisc, and if yes, how can I do it? Best regards, and thank you for the held (I've searched this question but didn't find it) Quote Link to comment Share on other sites More sharing options...
kgallen Posted March 9, 2021 Report Share Posted March 9, 2021 There are a lot of unknowns here, you'll need to give more detail. With an SP/LP2/LP4 disc and an appropriate machine, it is possible in some circumstances to use "TOC Cloning" to allow you to regain access to the audio data. But there are a lot of "ifs"... http://www.minidisc.org/cloning_procedure.html Quote Link to comment Share on other sites More sharing options...
Ana Nunes Posted March 9, 2021 Author Report Share Posted March 9, 2021 Kgallen, thank you so much. I'll try! Best regards Quote Link to comment Share on other sites More sharing options...
kgallen Posted March 9, 2021 Report Share Posted March 9, 2021 OK, no problem. Good luck, let us know how you get on if you're confident of having a go! Quote Link to comment Share on other sites More sharing options...
NGY Posted March 9, 2021 Report Share Posted March 9, 2021 4 hours ago, Ana Nunes said: I would like to know if it is possible to recover erased files from my MiniDisc, and if yes, how can I do it? Welcome to the forums. @kgallen already gave you some good directions, and I don't want to hijack the topic, but your question above was a bit ambiguous for me. When you mention "files", do you literally mean files (like on your computer), our you mean "tracks" (like on your CD-s)? Both are valid questions, however, these terms can refer to different, disctint kinds of minidisc formats (i.e..: legacy, netMD, HiMD, data) used, and thus the unerase procedure is also different (if not impossible, in some of those cases). Quote Link to comment Share on other sites More sharing options...
