i got a nw-a3000 and filling it with cp, ok till yesterday everything worked fine until cp refused to recognize my nw. i tried using different usb ports --> no result. i saved all my music fromt the player to my hd in the believe, if cp would recognize my player again i could easily recover my songs from the backup. So i formated the walkman and replugged it to the usb port, and guess what - it worked, cp would recognize my player again! i was happy, but only for the first few moments.
The next thing i did, was filling the a3000 again with my files form the backup (btw. mostly mp3 coded, only a few atrac rips from cd). In the library everything looked the same like before (yeah i cleared my library too, to distinguish between files i had on my nwa and files i had on my hd). BUT when i tried to submit the files to the player it said something like (i got the german version, but i hope i translate it right somehow) "file format not supported". SHIT i thought first, but then i rememberd that the files are stored on the player with mp3codec, just with this nifty .oma file ending.
So i renamed one file to *.mp3 for testing purpose and checked in winamp if the file would still play. it did. But all the metadata was gone no id3v1 no id3v2 tag - nothing. hmpf. At least CP transmitted the file to the nw which worked out well, except for the meta data like artist, titel,... you know the rest.
Now my question: Is there any way to get the files onto the nw again _with_ the metadata included? When i put them into cp as *.oma files the meta data is there, but it's gone as mp3. I don't want to rename every single file by hand... if you know any other way, please tell me
haissem
ok, first post, so hi all!
now to get straight to my problem:
thanks guys
4 answers to this question
