himd_anxiety Posted October 24, 2006 Report Share Posted October 24, 2006 (edited) My hard drive was wiped clean, and I had over 10,000 songs on it. Is there any way to copy them back from the player to my SonicStage directory? Any help would be immensely appreciated. Edited October 24, 2006 by himd_anxiety Quote Link to comment Share on other sites More sharing options...
himd_anxiety Posted October 25, 2006 Author Report Share Posted October 25, 2006 With all these views and no posts, I really feel like crap. Quote Link to comment Share on other sites More sharing options...
navsimpson Posted October 26, 2006 Report Share Posted October 26, 2006 If you've tried using Sonicstage and it tells you it won't allow you to transfer back - then, unfortunately, you might be SOL dude. Unless Sonicstage recognises the player as 'belonging' to that computer, it will refuse transferring back to My Library. Quote Link to comment Share on other sites More sharing options...
himd_anxiety Posted October 29, 2006 Author Report Share Posted October 29, 2006 navsimpson said: If you've tried using Sonicstage and it tells you it won't allow you to transfer back - then, unfortunately, you might be SOL dude. Unless Sonicstage recognises the player as 'belonging' to that computer, it will refuse transferring back to My Library.I actually figured it out, but thanks for your help, navsimpson. Quote Link to comment Share on other sites More sharing options...
glven Posted October 30, 2006 Report Share Posted October 30, 2006 would this work?http://www.atraclife.com/forums/index.php?showtopic=440 Quote Link to comment Share on other sites More sharing options...
himd_anxiety Posted October 30, 2006 Author Report Share Posted October 30, 2006 glven said: would this work?http://www.atraclife.com/forums/index.php?showtopic=440I will bookmark this. Thanks. This should work, too. I copied the OMGAUDIO folder to my hard drive, then opened each individual folder containing ATRAC files and imported them in SS. Quote Link to comment Share on other sites More sharing options...
planetpatsy Posted November 7, 2006 Report Share Posted November 7, 2006 (edited) can I use the GYM software if the music in my HD5 are ATRAC3plus? I have the following problem: had to re-install windows XP on pc so sonic stage will not transfer music back from HD5 to pc. I only managed to recover some of my mp3s on the pc so my entire collection sits in the HD5.Pls help. Edited November 7, 2006 by planetpatsy Quote Link to comment Share on other sites More sharing options...
