Electro_Q Posted November 29, 2006 Report Share Posted November 29, 2006 hi I have nw a3000, cant find install disk for connect so tried to install sonicstage 4.2 but every time it just freezes up and I have to use task manager to close. im using win xp2, I closed down any spy or antivirus stuff first but still freezes up Quote Link to comment Share on other sites More sharing options...
Ishiyoshi Posted November 30, 2006 Report Share Posted November 30, 2006 Welcome to ATRACLife!This error typically occurs because your firewall settings are preventing you from downloading the files. You may want to review your settings. Quote Link to comment Share on other sites More sharing options...
Avrin Posted November 30, 2006 Report Share Posted November 30, 2006 (edited) And remove any previous versions before installing 4.2. Backup your library (if any) before doing this. Then clean any traces of SonicStage, as described elsewhere in this forum, clean your TEMP folders, and restart your computer. Then try installing 4.2 again.SS42 installer does not remove previous versions completely. Some conponents still remain (like the OpenMG add-on). Edited November 30, 2006 by Avrin Quote Link to comment Share on other sites More sharing options...
Electro_Q Posted November 30, 2006 Author Report Share Posted November 30, 2006 thanks for help so far but ive checked all that, I have no firewall just a router. I have no previous sonicstage installed anywhere. Can you download full install from anywhere as that might do the trick . it normall gets to install and addon then freezes? Quote Link to comment Share on other sites More sharing options...
kerfuffle Posted December 1, 2006 Report Share Posted December 1, 2006 Some routers have built-in firewalls. And Windows XP SP2 has one. Quote Link to comment Share on other sites More sharing options...
