NW-S205F: sound-delay
zacka
Recently all the mp3-files I've transferred to my NW-S205F has a "sound-delay". The songs are so sloooow. Madonna sounds like a man and the beat is much slower than normal (sorry if I explain myself badly...)
I have'nt done anything different and the problem doesn't only occur when I transfer from one computer. I've transferred files from both my private-PC and work-PC.
I use VoidMP3FM to transfer. Anyone experienced the same problem?
Maybe I should try formatting the player and transfer the files all over again.
3 answers to this question
that's becouse you loaded a non 16-bit 44.1 Khz Mp3 file.
this player could only play a 16-bit 44.1khz sound. and will not resample other files couse it think that you used sonic stage that converts music before to load it.
if you hate sonic stage like me before to transfert convert the mp3 files to 16bit 44.1Khz VBR bitrate (V2 setting on lame that's a very high quality sound)
