MorganneRawks Posted January 12, 2007 Report Share Posted January 12, 2007 omfg i borrowed my friends mp3 and formatted it on my computer and now there is no database... WHAT DO I DO.... im missing all the folders.... i made one called OMGAUDIO.... im screwed.. plz helpmorganne <3 Quote Link to comment Share on other sites More sharing options...
pata2001 Posted January 12, 2007 Report Share Posted January 12, 2007 i borrowed my friends mp3 and formatted it on my computerWhy did you format it in the first place? all the music is gone now from the player. Quote Link to comment Share on other sites More sharing options...
kerfuffle Posted January 12, 2007 Report Share Posted January 12, 2007 I don't think there's anything you can do except to initialise your friend's MP3 Player. What model number is it? Quote Link to comment Share on other sites More sharing options...
Guest Stuge Posted January 12, 2007 Report Share Posted January 12, 2007 Why did you format it in the first place? all the music is gone now from the player.Add..Secondly, Never Format the Player using Windows Explorer,Format the player via advanced menu in the player .What model number is it?According to Topic tile its NW-E003F. Quote Link to comment Share on other sites More sharing options...
jonny mac Posted January 14, 2007 Report Share Posted January 14, 2007 So you borrowed your pal's player & wiped it? Nice one. Try formating it with Sonicstage although I'm not sure if that will work or not...But the songs are gone. Quote Link to comment Share on other sites More sharing options...
Christopher Posted January 14, 2007 Report Share Posted January 14, 2007 Welcome to the forums. As the others have stated, there is likely no chance that the music can be recovered with conventional methods. If your friend put music on the player via Sonicstage, just have him/her connect the player back to the original computer and reinitialize the unit. Quote Link to comment Share on other sites More sharing options...
