Question: Sony NW-E407 with MP3 File Manager
Ipecac
Hey guys,
Finally found a forum that may be of some help. I bought this a year ago and worked great for pretty much a year. Then I went to transfer files on to it and they went on the player but wouldn't play. The weird thing was the older files I had on it would. It bothered me for awhile why any new files on put on it wouldnt play, but older ones would. So I reformatted - but now I couldnt get anything to play - all files and software - did the same as usual - transferred the mp3 over but again - cannot play - would always come up. I did everything I could to get this thing to work but to no avail. Finally sent it into sony - got it back last nite same &*^%*&^%*&^% thing.
Finally had a break thru - why I have no idea - but sonicstage actually works ( well as much as it can ) - now i can transfer files with sonic stage and - they actually play. I hate this thing and really rather not use it - I haven't looked in to it but if does lossless transfers I might be more willing to use it?
Now when I use MP3 file manger to transfer files over - it does - but again - cannot play. I was hoping that any has earlier versions of mp3 file manager 1 or 1.2 - I'm using version 2 - and I think that is where everything went wrong. I have looked around and cannot find earlier versions - every link I find I get Timed out or link is dead? So if anybody has earlier versions of file manager that could help me out - it would greatly appreciated. or maybe an alternative?
cheers....
5 answers to this question
You need the 2.0 version of the file manager for the e407. The older versions are made for other models. As for the MP3s - I sometimes get the <CANNOT PLAY> messege for some MP3s but that happens only with several files. Try to convert the MP3's to a higher bitrate. That usually works for me....Or you will have to use SonicStage...Didn't have any problems with it so far.
Hey guys,
Dude! I've got exactly the same problem! The thing with mine is, however that a while back my player (e507) was left in my pockets and went through the wash. :eek:
When it came out, I opened it up slightly to allow it to dry, recharged it, and to my releif it charged fine, and all the songs were still on the player and played fine.
I continued using the player for some time, keeping the same songs on the player, but recently I formatted, and put a whole bunch of new songs back on using MP3 File Manager- and NONE of them play!
They all give the "cannot play" message. I will try using sonicstage and let you know what happens.
OK. update:
out of sheer frustration I formatted the e507 to FAT using windows xp explorer.
halfway through the format I read another thread on this forum:
http://www.atraclife.com/forums/index.php?showtopic=3553
which describes basically turning the e407 into a shiny paperweight from doing the same thing.
I was worried, but let the format finish. Whe I unplugged the unit, the LCD screen said "Format Error". I formatted through the advanced menu, and then it displayed the sony walkman "blank track".
The unit was still blank in explorer - I tried installing MP3File Manager, but of course it did not work.
In the end I installed SonicStrage - transferred one track, and it played fine! It put all the missing folders back (NWWM, OMGAUDIO) and the track played OK.
I then copied a backup copy of MP3 File Manager back onto the unit, and it ran OK, displaying the tracks correctly etc. I uploaded one track to the 507 using MP3FM, but again.. "Cannot Play".
I deleted the MP3FM folder and ran the original installation program, but it could not detect the e507 to install the program. Weird.
Well, at least I can still use sonicstage for the time being - but I'd really like to work this out!
