NW-HD3 Bookmarking Tracks
daft_drummer
So. You click round the menu's and you find the one with 'new tracks' and 'bookmark'. A while ago i was in the car, listenin to it, when i accidentally sat on it. This bookmarked the track! However, its happened twice since then and want to know the real way of bookmarking and un-bookmarking tracks(without sitting on it and damaging it)
PLease help a confused guy. :unsure:
Thanks in advance.
2 answers to this question
While a given track is playing, press and hold either up or down for a couple of seconds to bookmark it. Unbookmarking works the same way. Be sure to let the player turn off on its own or use the menu button - if you turn it off using the switch on the bottom, the bookmark won't be saved.
-Nav
