SonicStage Re-initialization Help
rocketor
Hi all! I have a little problem with my Walkman and sonic stage.
I got some viruses on my Pc, soi had no choice but to format it .
Now to the problem. I installed again the sonic stage (the latest version), but when I plugged in the player its says that I have
format it because im using different kind of sonic stage version . Is there anything i can do but not formating it . IT took me long time to aranged the songs , and many of them i dont have any more on my pc . I tried to install older version of sonic stage , the same thing. I have nwa 1000 .
Thanks to all!
5 answers to this question
I'm afraid there's not much you can do. I think the no-initialization "feature" in Asia Pacific versions of Sonicstage works IF the previous version of SS you use is Asia Pacific too. If you're going from a different region (eg: US), it might still ask for re-initialization. As a general advice, if you have a DAP that requires a software to transfer music, DO NOT delete your music on the PC. At least back them up somewhere.
I backed up almost all of my songs . the problems is that i dont want to format the DAP
because its really a big headache to arrange all the songs by the id3 tag again .
Is there any way like to transfer the data from my Walkman to pc and then some how to synchronize it with sonicstage?????
