Auto Sync Auto Delete ?
kithng
Hi all,
I'm new to Sony player, so I'm new to SonicStage. I've used ipod before and itunes served me fine. Now in SonicStage, I've created a dynamic playlist which randomly create 7 GB of music from my 30GB library, so I can update my player with random song anytime.
Here is the problem.
Is there a feature which tell sonicstage to delete the file from the player and sync my new random playlist to it ?
Seem like i need to delete all the track inside the player before i can sync my new playlist. Is it true ?
I would be great if it work like itunes which i press "Sync" it does everything for me.
Thanks for any help.
Kith
well u can automatically transfer dynamic playlist to u r player simply by automatic transfer. and it will upload all u r songs to it. without any porblem but be sure they all r unprotected mp3 s. but i prefer manually transfer mostly.well plz use ss 4.3 as it is much smartter. and does not copy multiple tracks.
Hello Kith,
I really never thought about this before. To automatically update the files on your NW-A808 does not exist in SonicStage. You would have to manually delete your files from your player. Either in your player or in SonicStage before you transfer your new tracks. However, it is possible to delete the dynamic playlist from the player then transfer it again.
The ability to have a randomly selected tracks on your NW-A808 each time you sync would be great. We should place the dynamic play list Random-Update Sync on our wish list for the next SonicStage.
