pomj Posted June 18, 2007 Report Share Posted June 18, 2007 All movies I convert is mirrored after conversion !?! I can not find any setting that controls this. Anyone knows what I'm doing wrong? Quote Link to comment Share on other sites More sharing options...
pomj Posted June 18, 2007 Author Report Share Posted June 18, 2007 The converted film is upside down and mirrored. The supplied spiderman trailer is not like this.I've uninstalled and installed again two times but to no avail. Quote Link to comment Share on other sites More sharing options...
LuLu Posted June 19, 2007 Report Share Posted June 19, 2007 The converted film is upside down and mirrored. The supplied spiderman trailer is not like this.I've uninstalled and installed again two times but to no avail.Can you provide more details about what films (format, size, aspect ratio) you are installing?LOG Quote Link to comment Share on other sites More sharing options...
pomj Posted June 19, 2007 Author Report Share Posted June 19, 2007 I'm at work now so I'll provide that info when I get home. I did however test with iRiverter (using ipod profile) and then it was ok albeit the quality didn't seem to be on par with those converted with imageconverter.could it be any codec that is not installed? But shouldn't the program complain in that case? Quote Link to comment Share on other sites More sharing options...
pomj Posted June 19, 2007 Author Report Share Posted June 19, 2007 Can you provide more details about what films (format, size, aspect ratio) you are installing?E:\-- film --\-TV-\nnn\Season 1\Ep 1.avi175 MB (179,428 KB / 183,734,272 bytes)File Length CorrectAVI v1.0Interleave: 1 vid frame (42 ms), preload=480Audio frames: Aligned on interleavesVideo: 151 MB (86.56%)Audio: 21.5 MB (12.27%)AVI Overhead: 2.03 MB (1.16%)Audio: 0x0055 MPEG-1 Layer 348000Hz 133 kb/s tot , Joint Stereo LAME3.93 Codec(s) InstalledXviD ISO MPEG-4Codec(s) are InstalledPVOPKeyframe (I-frame distance) 120.4 avg / 489 maxLen:22:35.802Frame count 32,507Avg bitrate of videostream 938frame quality 0.166pics/s 23.976frames/s 32,507640 x 368storage aspect ratio 1.739 (40:23)pixel aspect ratio 1.000 (1:1)display aspect ratio 1.739 (40:23)I *really* hope anyone can help me Quote Link to comment Share on other sites More sharing options...
pomj Posted June 19, 2007 Author Report Share Posted June 19, 2007 *SOLVED*First I realised that mpeg movies were converted flawlessly. I reran Gspot noting that xvid *was* correctly installed. (Vista codec pack). I took a chance and reinstalled with another xvid release and now it works correctly. Quote Link to comment Share on other sites More sharing options...
LuLu Posted June 20, 2007 Report Share Posted June 20, 2007 *SOLVED*First I realised that mpeg movies were converted flawlessly. I reran Gspot noting that xvid *was* correctly installed. (Vista codec pack). I took a chance and reinstalled with another xvid release and now it works correctly.Good! I was going to suggest you try another format, preferably MP4 (and one that I had already downloaded and got to work on my A806). BTW, I found a site with some videos:http://www.dailypspmovie.com/LOG Quote Link to comment Share on other sites More sharing options...
