djmalice Posted June 23, 2007 Report Share Posted June 23, 2007 Can i have a photograph as my screensaver? Quote Link to comment Share on other sites More sharing options...
0 Shinji Ikeda Posted June 23, 2007 Report Share Posted June 23, 2007 Can i have a photograph as my screensaver?With the current firmware there is no way of using screen savers other than the default. You can however use the built-in slide show like a screen saver. Just remember to set the slide show last. Quote Link to comment Share on other sites More sharing options...
0 dita Posted June 25, 2007 Report Share Posted June 25, 2007 With the current firmware there is no way of using screen savers other than the default. You can however use the built-in slide show like a screen saver. Just remember to set the slide show last.that's pretty neat! I'm going to try that Quote Link to comment Share on other sites More sharing options...
djmalice
2 answers to this question
