Error 00007180
ShriDurga
Hi, everyone. I'm very happy to have found this community. Maybe some of you can help me with a little problem I began encountering today with Sonic Stage.
I"ve been running the program for a few weeks and only as a means to get music from the computer to my MD Walkman. The mp3 files are on a different computer than the one on which SS is installed. Through my home network I've been copying to the Library and then onto the MD.
This was working fine until today. I have 3 new albums and was able to import to the Library only 1 or 2 tracks for each album. Deleted those, restarted the computer, tried again, same problem.
Then I started looking around and found you. The FAQ gave me the idea to copy those files to the computer that has SS installed. I was then able to transfer 4 tracks to the Library, after which I get the [Cannot find music files that are not registered to SS. Error Code: 00007180]
Is this likely to be a continuing problem? Any known workarounds?
Many thanks in advance.
SonicStage : 4.3.01.14050
Dell XPS M1710 Vista
SD
  • 1 month later...
I had this exact problem.
I had some WMA files ripped using WMP11 to D:\Music\Album1 and D:\Music\Album2
They would not import, giving a 00007180 error.
Moving the files to the system My Music folder, the exact same files imported perfectly...
Damn buggy SonicStage again. Sony Software is the embarrassment of the Sony division.
