ML_Sony: Supported Versions of Winamp
manxian
Hi
Having just *discovered* Winamp and had problems using it to download music to my NW-A1000 and having read through many threads it would be really helpful if I could have a definitive view on what versions of Winamp are supported by Ml_Sony.
I installed Winamp V5.35 (latest on the site) and, while everything appeared ok, Sending Tracks to G:Sony Walkman resulted in absolutely no change in the Sony Walkman pane i.e. no + or M, no additional tracks being shown and no option to *Apply*. In short nothing appeared to have happened.
As a result of reading this forum I decided to try Winamp V5.33 and it appears to have worked! (Need to try everything but initial tests seem ok).
My question is: what versions do we believe are supported and is there anything I can try to make Winamp V5.35 work? I'm concerned about the *security vulnerability* of V5.33.
FYI I'm running XP Home SP2, NW-A1000 with V3.0 firmware.
Thanks for anyone's help.
Hello manxian,
Apparently the plugin stopped working after v5.33,
I am not sure of the problem but I am thinking it has something to do with the GUI and the new winamp SDK,
if you are a developper you are welcome to take a look at the code on source forge,
you should look to modify ml_sony/view_sony.cpp
It should not be very difficult, it's just that I don't have the time to work on anything else than the new library version.
Let me know if you need help
See ya
Thanks, otiasj.
At least I now know for sure. We can all only be grateful for the work you have done so far, and your dedication and support.
Not sure I'm up to modifying the code - my days as a developer are in the dim and distant past.....! I will take a look though.... never say never!
Thanks again.
Thx for the support :-)
For those who wonders :
you need a svn client like tortoise svn to get the code from souceforge,
and you need Visual studio to compile (I am using 2005),
use the project named "Test" as it shows example of use of the SonyDb library
hope you guys will start developping GUI or help to improve the library code!
