invictus Posted July 24, 2007 Report Share Posted July 24, 2007 Hey All,I just bought a nws-205f Sony Flash MP3 Player - Can someone please tell me how to how to add new tracks to the "Run" playlist that came with the machine? Thank you so much! Quote Link to comment Share on other sites More sharing options...
0 Zizone_ Posted July 24, 2007 Report Share Posted July 24, 2007 (edited) All you had to do was to perform simple search about Playlist at ATRAClife.Anyways, I am copy/pasting previous comment:One can say the playlist replaced folder (or "group," the term used by earlier SonicStage). In order to create playlist, which functions much like a "folder," (or "group") click a playlist box located in upper right corner from your SonicStage 4.3 (right next to the bar indicating amount of memory left in your computer). Once you click, you will have two sections, much like having list of songs in your computer on the left hand side and songs in your Walkman on the right hand side; only difference now is that right hand side is a playlist while the left hand side remains the same, songs in your computer. Now, you may move songs from your left hand song list into the right hand side, the playlist. Here, you many create folder and move songs with unrelated artists into that folder in any way as you please, including any song order. After you are done creating your playlist (or folder), close the right hand side list (the playlist) by clicking the box, which you clicked to open the right hand list (one that is next to the bar indicating amount of memory left in your computer).Now, you probably want to transfer this particular playlist (folder) to your Walkman. To do this, click a box found in your far left hand side saying displaying mode, e.g. Album/songs, into Playlist. After this step, you will see the playlists (folders) you created previously. Then simply transfer this playlist into your Walkman like you would normally do. Now, you have songs in a way you wish.To view the playlist in your NW-S706, click Playlist by accessing menu from your Walkman. By pulling Jog Shuttle out, you will be seeing folders and by pulling Jog Shuttle in, you will be seeing songs within that particular folder.try this link. playlist Edited July 24, 2007 by Zizone Quote Link to comment Share on other sites More sharing options...
invictus
Hey All,
1 answer to this question
