Is the NW-A808 MAC compatible?
7 answers to this question
Videos are drag-n-drop, so if the A808 is a USB mass storage compliant, it should be detected as an external storage with any OS.
Also, Intel Macs can run windows using bootcamp.
  6u0W said:
Are you sure??? i did some tests and couldnt get it to work.
You can not use it *together* with SS. Well you can use it to get music off the player but if you try to upload music SS thinks the database is corrupt. But if you use the OMGAudio folder they have on their site you should be all set (I think)...
Essentially if it works for linux it works (or can be made to work) with mac. (oooh I wish I had one)
