I was wondering if anyone else out there is having eq problems with their a1000/a3000.The problem being the fact that when i use my eq the volume drops heaps even though the volume on the player stays the same. Therefore when i use the eq, max volume is lower then when i have the player on max volume without the eq on? The sound pressure therfore drops when i turn my eq on....is this normal? The player has done this since i brought it over a year ago
Thanks heaps,
i was also wondering if their is a way to change the bass frequency of the eq to say 60hz or something using the service manual?
stargazer_tom1
Hi,
Thanks heaps,
thanks again guys,
any help will be appreciated
3 answers to this question
