So I bought this for my sister-in-law 2 weeks ago and it just turned up! I promised I would set it up for her and test it out as it's her very first mp3 player and I wanted to get it ready.
Well, thank God I did, or I suspect she'd have dumped it already!
I've just plugged it into the usb port as per instructions - and all that happens is the dreaded yellow? pops up and the computer starts trying to download software for it - an mtp error???
It is not visible in 'My Computer' and I can't get it recognised at all.
The unit is operable when it's not plugged it, ie; homepage, settings etc are available, but it won't connect.
Windows Media Player can't see it either, and as it's supposed to be an easy drag and drop device, I'm at a loss to know where/what I'm doing wrong.
According to the 'quick start' guide - as soon as it's plugged in, Windows should ask what I want to do, then I'm supposed to select "Open folder to view files" - but I'm not getting that option, only the one I mentioned.
Can anyone help? I want to start charging it and I can't even do that!!
juli_
I've just plugged it into the usb port as per instructions - and all that happens is the dreaded yellow ? pops up and the computer starts trying to download software for it - an mtp error???
4 answers to this question
