paulbsrje Posted May 13, 2008 Report Share Posted May 13, 2008 My hd3 is dead,just a brighter screen when powered on.My plan is to source and replace the hard drive.The hard drive is I believe a MK2004gal (a 3007 or4007 could be used).All the ones listed on ebay state that they are for ipod.Does that matter?Is there any other UK retailer I should consider?Are there any other issues with this apart from putting it all back together!!thanks Paul Quote Link to comment Share on other sites More sharing options...
0 Guest Stuge Posted May 13, 2008 Report Share Posted May 13, 2008 Welcome to AtracLife !I'm not sure ,but my HD3 uses MK2006galhttp://www.atraclife.com/forums/index.php?...c=536&st=10You don't have to worry about whether its listed for an Ipod or not .Just get the right model no . Quote Link to comment Share on other sites More sharing options...
0 paulbsrje Posted May 14, 2008 Author Report Share Posted May 14, 2008 (edited) Definatly a mk2004gal as I have just dismantled it!Off to search for a good new drive to see if this will fix it!Putting it back together could be fiddlythanks for response.Paul Edited May 14, 2008 by paulbsrje Quote Link to comment Share on other sites More sharing options...
paulbsrje
thanks Paul
2 answers to this question
