Using the NH-B105 software with a NWD hd5 Walkman
nylon99
5 answers to this question
Hi LG1
Thanks for the reply, I'm no tech novice and as I'm hardly using my "5" now simply because I prefer the "105", I'm happy to give anything a go. Is there some hard ware preventing me wiping the drive and just installing the software?
Aah is it the control interface for the device itself??
Anyone else got any ideas??
Ny
MP3FM wont wipe anything, if there is allready mp3s on it, it should work fine and not wipe anything on it.
But if the device is formatted you need to use SonicStage and get the files back and then it will work.
So basiclly just use MP3FM on your HD5 should work fine
