NW-A1000 Formatted in a PC
gokou
1 answer to this question
Hi,
Is it not possible for you to start your nw-a1000 and choose in the menu settings and Initialize Disk?
If not then try to format your player in windows be careful and choose FAT32 as system, after the reformat start SonicStage and try to transfer some music.
Disconnect your player and as all is well you see Creating Library on the player, may be you get a message after that but your player must be working well.
I tried this with my NW-A3000 (Format in windows as FAT32 and after that SonicStage could transfer music to my player) and my player was working, to be sure I also choose Initialize Disk on my player in the settings menu after this operation and loaded my player again with music via Sonicstage.
I hope this is helpful for you.
Greetings,
Jan
