rblanco10 Posted December 4, 2002 Report Share Posted December 4, 2002 Hello, I have been looking into the Sony RM-MC12ELK Universal MD remote, and the Sony RMMC11ELS universal MD remote. Which one is better for the Sony MZ-G750 MD Recorder/Player? I realize that both of the mentioned Sony remotes above will not operate the AM/FM tuner of my Sony MZ-G750 MD Recorder/Player. I am looking for a remote with a lit LCD display, a jog lever to enable programming of tracks (with the hack MZ-G750 to MZR900), and easier access to volume control and other functions. Is the more expensive Sony RM-MC12ELK Universal MD remote worth the price? Thanks, Ruben cyber_ruben@yahoo.com Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted December 5, 2002 Report Share Posted December 5, 2002 Both remotes are bascially the same with only two basic differences. The Lcd and the size(this effects location of certain things). The LCD on the 12 is IMO a better one. it displays characters bigger and has a different font than the 11. as for controls, both are almost the same. the only difference is that the stop button and head phone jack is located in different places. on the 12 the head phone jack is on the opposite end (tip) as the cord. the 11 has a proturding bump that hold the jack while the tip has the stop button. the 12 has the stop button next to the other buttons on top of the lcd. i would suggest getting the 12 cuz its smaller, has a better jack location (IMO) and has a higher resolution LCD.. just my 2 cents. Quote Link to comment Share on other sites More sharing options...
Mystyler Posted December 5, 2002 Report Share Posted December 5, 2002 The 12ELK is designed to display Japanese/Chinese characters, and this is probably useless to most Westerners. It also has the ugliest text on a remote I've ever seen. 11EL is the way to go, cheaper, and you don't end up paying for features you don't use. Quote Link to comment Share on other sites More sharing options...
rblanco10 Posted December 5, 2002 Author Report Share Posted December 5, 2002 Thanks for the reply. Yes as a Westerner I would not take advantage of the extra functionality that the 12 has to display Japanese/Chinese/etc special text characters. All of my minidiscs are labled in english (no need to display special characters.) So the 12 does have a brighter display? I have seen some pictures of it and the blue text with the roman lettering, with the gap spacing looks wierd. The 11 on the other hand has a wierd design where the earphone jack is a protrusion on the back of the remote. Does the scrolling of the text differ between the 11 and 12 remotes? I read that the 12 jurk scrolls, is the 11 similar or better? I am still trying to decide which one to get. Any more advice, or any more purchasing points to favor one remote over the other would be great! Thanks!!! Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted December 5, 2002 Report Share Posted December 5, 2002 the lcd on the 12 is brighter and is different in color. i can say from using both remotes that the 11 does have better scrolling. Quote Link to comment Share on other sites More sharing options...
mAjEsTiC Posted December 5, 2002 Report Share Posted December 5, 2002 the 11's text scrolling is smooth, kind of like on the display on the r900...itz nice and does'n "jerk" or jump... Quote Link to comment Share on other sites More sharing options...
