Checking in LP2-LP4 mode
Guest Anonymous
Guest Anonymous
When I transfer mp3 file from computer to MD some files are transferred in LP4 mode, but some can be transferred only in LP2 mode (although I indicated LP4 mode in OpenMGJukebox)
Second question: are there any programs for transferring music from computer exept OpenMG Jukebox and SimpleBurner?
If you have a file that you encoded in LP2 mode (132 kbps,) then it probably can't be transferred as LP4 mode unless you reencode the file at a different bitrate.
The RealOne player has a plugin that allows NetMD transfers (I think.) Other than that, there really aren't any programs other than the Sony crapola that come with the recorders. However, there are people out there working on better programs for NetMD.
