me Posted December 11, 2002 Report Share Posted December 11, 2002 If you get an error along the lines of 'Can't Read' or 'Disc Err', your lens may be dirty. This is simple to fix, really. Now, commercial lens cleaner discs are a waste of time for anything but the largest hairs and other obstructions.. They may even scratch your lens further. What has worked for me, and Mystyler, and a fair few other people no doubt, is obtaining some 91% (or if you can find it, 99%) isopropyl alcohol. NOT rubbing alcohol. 1. Take a cotton bud, and dip it into the alcohol. 2. open your MD unit, and apply the alcohol to the lens (clear thing with a blue hue to it, made of plastic). Make sure you DO NOT get alcohol on anything but the lens. 3. allow the unit to dry for at least half an hour 4. problem solved, hopefully. 5. don't blame me if your hand is slack and you flood the unit in alcohol, or if the method doesn't work. http://repairfaq.ece.drexel.edu/REPAIR/F_c....html#CDFAQ_027 is my source. Quote Link to comment Share on other sites More sharing options...
dannn Posted December 11, 2002 Report Share Posted December 11, 2002 another tip if you are going to use a MD lens cleaner beware there have been reports of certain cleaners that will scratch the lens instead of cleaning it!! -dan Quote Link to comment Share on other sites More sharing options...
