My recording experience
Fernando Olmos
Just a quick tip...
For those that have portable MD units with both microphone and line-in inputs, the best recordings, are through the line-in IF you're using a batter powered microphone or binaural microphone setup. If you plug those battery powered unit into the microphone input jack, you're bound to get distortion above the 2-4db range. I only used the microphone line for non-powered mics, and the distortion is almost gone. But for live concert recordings, you cannot beat the quality and realism of a pair of battery powerd binaural mics, especially with a bass-roll off if you can get one.
Cheers
