erwin Posted December 17, 2002 Report Share Posted December 17, 2002 i have a 707, if i put the drive in the charger, the batery icon doesn't begin to flash in the display, in the manual it said that it can take up to 3 minutes before it begins. i waited an hour and still nothing. all cables are connected properly off course. is this normal and is it charging without anything on the display or is the charger defective? Quote Link to comment Share on other sites More sharing options...
ludde Posted December 17, 2002 Report Share Posted December 17, 2002 No, thats defenitly not normal. A friends of mine have hade almost every problem you can have with his N707 and he haven't heard of this. Check that everything is properly connected one more time, then if you can trie another charger. If that dosn't work buy a new battery. Also try charging the batery in another unit if possible. Otherwise I think you're doomed to Sony Service if no one else have any ideas!. Hopefully you got some sort of warrenty.. Good luck! Quote Link to comment Share on other sites More sharing options...
erwin Posted December 17, 2002 Author Report Share Posted December 17, 2002 i'm still within 8 days so i'll change it for anotherone thanks Quote Link to comment Share on other sites More sharing options...
darK (aka Tharaka) Posted December 18, 2002 Report Share Posted December 18, 2002 Quote i'm still within 8 days so i'll change it for another one- that means its a brand new player?? Quote Link to comment Share on other sites More sharing options...
erwin Posted December 18, 2002 Author Report Share Posted December 18, 2002 yes, tested with other psu, worked fine. will get replacement after work today. Quote Link to comment Share on other sites More sharing options...
erwin Posted December 18, 2002 Author Report Share Posted December 18, 2002 have a replacement allready, it works. great!! Quote Link to comment Share on other sites More sharing options...
darK (aka Tharaka) Posted December 19, 2002 Report Share Posted December 19, 2002 cool.. r u gonna do the hack on ur new one as well? Quote Link to comment Share on other sites More sharing options...
