Problems with S38 loading mechanism
triplea
There is a problem with my Sony MDS-S38 minidisc deck disc loading mechanism. When the unit is on, and there is no disc in it, the mechanism makes strange sounds and the display flashes and switched between "eject" and "loading" and idle. When a disc is inserted, it don't go all the way in, but stutters back and forth, and sometimes gets jammed. I have had the unit repaired once, but the problem came back after some months of shifting use (never really heavy).
Is there a real sollution to this problem, or do I have to buy a new deck?
If it is still acting up since you had it repaired it might be time to junk it - if you can afford to get it fixed well and good since the S38 is a funky deck, but I would think you'll be very happy with a newer deck, and all the nice new features that come with it.
