My 2 cents
Omad0n
The one thing that I thin is missig, and it kills me is from the Forums section. I'd like it if we had the option to go to last post read. If it's not possible in the software used to run this forum, then bummer. BUt as some threads get LONGER and LONGER it's real nice to go just where you left off. Also if you haven't been around for a few days it's helpful too.
Not exactly starting from where you left off, but this forum does give you these three options:
View posts since last visit
View your posts
View unanswered posts
They are located on the main page of the forum, on the top-right hand corner.
Omad0n, this is already possible - all you need to do is find the thread you want, and click on the "burn orange" icon that looks like a piece of paper with the tip folded, which is next to the thread title and a small black arrow.
Ywah I know of that, but sometimes I don't rememebr what was in that particular section. So I wanna read like the 1st post to refresh my memory. After all this is n't the only Forum I haunt. By this point though I don't have what I need. From like the vBulletin boards, which have that go to last unread button in the acutally post.
