Modify E888LP in 4 polar jack system for Sharp DS8
Guest Anonymous
Guest Anonymous
Hi!
As you know, Sony E888LP are very very good earphones :wink: . But when you just buy the best minidisc player too, Sharp MD-DS8, there is a problem!
If you want the best sound with Sharp DS8, you should use 4 polar jack system earphones rather than 3 polar standard jack system. DS8 is made to be used with 4 polar jack system earphones. The problem is here: how to do with Sony E888LP's 3 polar standard jack system?
Somebody has already tried to modify its E888LP into 4 polar jack system? Where can man buy 4 polar goldplated jack L plug? :?:
It should be possible though.. But i'm fairly certain Sony's wires are covered in an enamal, and are tricky to solder. And your buds wouldn't work with normal 3 polar equipment.. Hmmm, I need some sennhesier MX400s. That would be an ideal candidate.. Oh man, I don't want to kill these four pole buds though. Heh.
  • 3 months later...
