707 hack questions
Guest Anonymous
Guest Anonymous
does the 707 automatically remember the each disc or do you have to set it to remember, and i can't find sound set, which came originally with the 707 and how to set the speed for the disc.
  • 4 weeks later...
Guest Anonymous
Hi
I have the MC12ELK remote, but I believe its backwards compatible to the MC10 and MC11EL...
Anyway, on the remote, to edit the sound settings, hold down 'Sound' for approx three seconds and the first EQ alteration b(ass) comes up which you can alter with the track access jog dial... hold down Sound again for another couple of seconds to access the treble...
and when settings are finished press enter for it to be saved...
Speed ~ if you hold down the display button on the remote for a few seconds an edit menu comes up, move through the options with the jog dial until speed comes up, press enter... and there you have it smile.gif
  • 3 months later...
