Guest Anonymous Posted January 21, 2003 Report Share Posted January 21, 2003 I have a cd player that has an optical out and a coax out. I would like to use these through a USB input on my MZ S1, Is there an adapter to do this that does not require use of a computer? Quote Link to comment Share on other sites More sharing options...
Bazirker Posted January 21, 2003 Report Share Posted January 21, 2003 http://forums.minidisc.org/viewtopic.php?t=378 Quote Link to comment Share on other sites More sharing options...
MDX-400 Posted February 3, 2003 Report Share Posted February 3, 2003 USB input on the MZ-S1??? (Or any NetMD for that matter...) That connection is for NetMD only (i.e. connection to a computer for ATRAC3/MDLP downloads). To get digital output from your CD player to the MD, simply use the optical output and connect to the optical input on the MD. There is no need to worry about the USB for that sort of recording. Note that the LINE input and DIGITAL input on the MD will likely share the SAME jack. You will need a widely available standard Toslink (square) to Toslink miniplug cable (or simply a regular cable with mini adapters) to get the digital connection working between the CD and MD. Roland M. Quote Link to comment Share on other sites More sharing options...
