Software other that OpenMG?
Foxfire
I will not answer you directly as I hope others will. Let me say this: When you get your unit, install the SONY software, then the SONY drivers, make sure it works, then worry about workarounds later. Many have had problems getting their units working and I suspect it is because they try SimpleRecorder or RealPlayer first rather than just getting the standard stuff installed. Also, check for updates on the Sony support site.
Not really....sonicstage 1.5 is basically the same thing as openmg with a better interface and fewer bugs...so i recommend it over openmg. You can patch openmg and it makes the program less buggy; if you have the program I'll help you track down the link to the patches. There is a plugin for Realone player that allows netmd transfers, which some people prefer over openmg or sonicstage. I personally don't have any experience with realone yet. People are working on creating netmd programs, like win nmd. There still aren't any programs yet that can totally replace openmg and sonicstage...maybe time will fix this.
Edit: and I forgot my favorite way, using simple burner and dino's nero image method. This is kinda a pain though because you have to use three different programs to make an md.
