2 second gap
Guest Anonymous
Guest Anonymous
After redording from cd using the realone plugin, the tracks have 2 seconds of silence at the end of each one. Is there any way to remover this via the player? The tracks are not protected or anything, (sorry im new smile.gif)
Well, if there's a 2 second gap added at the end of each track (like, the timer says 4:30 when the song is actually 4:28) then what you can do is on the player make a new track right when the silence begins...Then just delete the newly formed track (which will just be silence). If it is like -0:02...-0:01...0:00 then I'm not sure this method will work.
Guest Anonymous
Thanks for the advice. Is there anyway to prevent realoneplayer adding the gaps in however, that would make things a lot easier for me sad.gif
Guest Anonymous
use sonicstage or simple burner instead, no problem like that in them.
I do use simpleburner but I dont have Nero imagedrive, so I can use it for mp3. does sonicstage convert mp3s and also does in have the check in/out etc?
