MZ-R500 serious problems need help
Guest Anonymous
Guest Anonymous
i just baought a used MZ-r500 and then i got a battery charger from the store and a rechargable battery but it seems that the MZ-R500 doesnt support rechargable batteries. is it tru that i cant use rechargable battteries on this MD or can i use them. if i can how do i recharge? thx a lot!
I don't think the R500 had recharging capability... (I could be wrong on that but I'm pretty sure).
The R500 was a value (low cost) unit that, unfortunately, was TOO stripped down. In addition to no mic jack, it lacked both recharging and the remote port on the headphone jack. Neither a rechargeable can be charged in the player or a remote be used, even by "adding them at a later date".
I believe Sony realised they made the unit a little too featureless and they corrected that in the MZ-N505 low cost unit when they "added" recharging and the remote port to the non-microphone unit in the line. Eventhough in most locales the remote and battery were not provided, they could be added later.
So anyhow, it looks like the R500 can't recharge a battery. You can always use a rechargeable but you'll have to charge it with a separate recharger...
