BrewMan Posted February 22, 2003 Report Share Posted February 22, 2003 I'm trying to get OpenMG or Sonic Stage to see my NetMD player (N707). I can use it with Real One, and with Simple Burner, but when I use either of the other programs it doesn't see my NetMD player. I have the latest versions of both programs, and I had initially installed OpenMG then I dl'd and tried Sonic Stage. For some reason I can't use these programs with my player. Note: I bought my unit second hand and had to DL the software from Sony's Website because the original disk was lost. Any help would be appreciated. Thanks in advance. Link to comment Share on other sites More sharing options...
Sugo Posted February 22, 2003 Report Share Posted February 22, 2003 If you can connect with realone and simple burner, then your netmd driver and physical connection should be ok. Was it not working already when you only had OpenMG installed? I would try uninstalling both and just install SonicStage to see if OpenMG is causing troubles. Make sure you install with the setup.exe in root of the zip file, not the one in sonicstage directory. Link to comment Share on other sites More sharing options...
matalmp Posted April 23, 2006 Report Share Posted April 23, 2006 BrewMan said: I'm trying to get OpenMG or Sonic Stage to see my NetMD player (N707). I can use it with Real One, and with Simple Burner, but when I use either of the other programs it doesn't see my NetMD player. I have the latest versions of both programs, and I had initially installed OpenMG then I dl'd and tried Sonic Stage. For some reason I can't use these programs with my player. Note: I bought my unit second hand and had to DL the software from Sony's Website because the original disk was lost. Any help would be appreciated. Thanks in advance.where did u download software i miplaced mine Link to comment Share on other sites More sharing options...
atrain Posted April 23, 2006 Report Share Posted April 23, 2006 this is a very old thread. please refrain from reopening old threads.sonicstage 3.4 is in our downloads section. Link to comment Share on other sites More sharing options...
