MZ-R500 Adustment
Guest Anonymous
Guest Anonymous
Hi,
i have a mz-r500 and some times it does not read my mds. so i opened it to clean. then i found a screw next to the laser. i turned this screw and after that the player always says "error" or "no disk". what should i do now? i tried to turn the screw back, but i don't find the right position
thank u
wasim from germany
Well needless to say you should have just cleaned the lens and NOT turned the screw! I dunno what that screw was for, but I'm thinking you might have done something to the Over-write Head (OWH), but then again you should be able to play discs okay if it was that.
Check out the Equipment Browser on the main minidisc.org site and see if there is a service manual there. If there is then perhaps you can find out what you changed. Barring that, you may have to get it serviced professionally before it will work again! Which may mean you might be better off buying another unit.
Also I'm moving this thread to tech support where, besides being the right section for this post, will probably get more attention there from others.
If anyone has any other ideas to help him out, let us know!
Roland M.
