Buying my first minidisc
Guest Anonymous
Guest Anonymous
I would like to have some things cleared up before I spend my money. Which model is better/newer the MZ-N505 or the MZ-N510? Also can you skip tracks on a minidisc like a cd or do you have to fast forward like a tape?
  • 3 weeks later...
Guest Anonymous
Get the MZ710 instead, it's a much better player for only slightly more money! It is flat (without the battery hump), as more functions, (amongst others a very neat 6-band equalizer to help you suit the sound to your liking) and the casing is made of aluminum instead of plastic.
MD is just like a CD as far as how it plays--you can randomise the disc, skip tracks, and (unlike the CD) delete a track if you don't like it and record something else it its place!
The 510 is newer, but I'd agree with the previous post: the 710 gives you more features you might find handy, even if it's just fine tuning the sound instead of relying on Bass1 or Bass2 presets.
Guest Anonymous
Sorry for my English... I have Sony MZ-N510. When I connect AC Adapter to the my MD I can hear strange sound inside. Click-clack.....10-15 second....Click-clack..... Then I pull out the jack of AC adapter (only battery is inside) and strange sound "is no more"! Can anybody tell me - what does it mean???
Guest Anonymous
No-o-o...
You know, I live in Russia and american (or what come with MD there..?) adapter is not for me (I need 220 V). I'd bought something and then plug it into... There are 3V, 500 Ma. There is no sign on the MD screen like "HiDcIn".. May I'm wrong and I should buy own Sony adapter???
