Guest Anonymous Posted April 1, 2003 Report Share Posted April 1, 2003 Hi there How can i record tracks on a minidisc onto a CD. I have got some old songs in casettes which i have recorded onto a MD. i want to make a copy for my friend on a CD. thanks veera Quote Link to comment Share on other sites More sharing options...
Leland Posted April 1, 2003 Report Share Posted April 1, 2003 If your MD portable has NetMD capability, check out this: http://forums.minidisc.org/viewtopic.php?t=435 Otherwise, just hook it up to a computer using the analog output from the MD (headphone if Line out is not supported on your unit) and hook it up to the line in on your computer sound card. Set the record level appropriately (requires a little experimentation if you want to optimize it to perfection) then record in real time. The wav file can then be burned to a CD. Quote Link to comment Share on other sites More sharing options...
