Remote for the mz-r500?
Guest Anonymous
Guest Anonymous
Is it possible to get a remote for the mz-r500? I know it does not come with one but is it possible to buy one as an accessory?
Thanks!
Any help is appreciated!
The 500 doesn't accept a remote, but the 505 does (even though the 505 ALSO doesn't come with one). If I remember right, the 500 is the only LP machine that wasn't designed for a remote--I hate to say it, but you might be screwed!
Keep an eye out, though. Now that Sony's introduced some new models, the old stuff (the 505, & 707) should get a little cheaper. A remote (even used on Ebay) will set you back about $45+, so you might just as well upgrade.
  • 3 weeks later...
Theoretically, you may be able to wire one up internally. I'm pretty sure that the internal lcd, and keypad use the same transmission medium as external remotes. It's probably a long shot, but if you have some soldering knowledge, and some pinouts, it may be possible to wire up a remote.
Id try it with my MZ-R500, but I dont really want a remote at this point :wink: . Maybe if I feel the need later on il try.
Edit: Open up the battery compartment, you sill notice 4 copper pads inside the minidisc player. Ive heard that these are points that are used in the remotes, so a remote may not be all that long of a shot after all.
