a few questions about sony MD N707
Guest Anonymous
Guest Anonymous
Ok I think i might want this. my primary purpose will be to record myself practicing my upright bass, and also recording of gigs and rehearsals. sound quality is not of the utmost importance, but i wouldnt mind something nice-sounding. from my understanding, i could plug in a mic and that would be all the gear i need to record? the ECM-MS907 seems to be a popular choice. would this be a good mic? will it pick up the bass frequencies well?
also how much should i expect to pay for each piece? what are the new instore prices? what about ebay?
thanks a lot
The 707 is a great unit for this. You can still buy them at E-Bay, but the prices are starting to go up. Go figure!
The one thing to consider though, is the manual record level feature has to be re-configured after the unit is turned off. Most Sharp units stay in this setting even after they are turned off.
Sound quality is great and the record level setting is the only feature I can see that is a nusance.
I built my own mic, so I can't give any advise on that.
How loud do you play when you're practicing? I recorded myself practicing on my drumkit and I got massive distortion but I recorded our guitarist playing by himself on an acoustic guitar and the recording sounded fine. I ended up buying a battery box and now I record into my N707 through the line in.
In general though, you probably are better off with a sharp if you're going to record live music. Sony units are notoriously bad when it comes to their microphone pre-amps.
--Matt
