should I get sharp MT180?
Guest Anonymous
Guest Anonymous
hi all:
I found sharp MT-180 is around 80USD on ebay, is it worth to get?
looks it has the basic function I need: recording and cheap.
any suggestion?
MArk
No! Don't get that one. A MD without remote are a pain to operate. Also that one don't come with any optical cable and of course no mic in either. Only unit, batter, eliminator and cheap headphones. Go for a model with better headphones and remote right away.
Why do you think that so many MT-180 are sold second hand? The owners are not happy with 'em and want to get a better one.
OK it's not totaly worthless as it have MDLP mode so if you can pick one up for less than $80 US, say max $60. Then do but your been warned.
A MD without Long Play are more out dated than a pre GSM (NMT) cell phone, can only serve as a curious artifact on your book shelf.
