Advice over purchase
Guest Anonymous
Guest Anonymous
I'm thinking of buying a Sony NetMD player. As I'm based in the UK, the MZ-N710 is off the agenda, as I've read it has very low sound levels.
The MZ-N10 is probably a bit too much money for me but the MZ-N910 and MZ-N1 are around the right price. Which of these two would be best?
Any advice gratefully received.
Guest Anonymous
Thanks for the advice, chaps.
I've looked at prices on-line here in the UK and the best price I can find for the N910 is £ 188 including delivery. The N10 is about £ 27 more expensive - is this worth the difference in cost, do you think, or is the N910 as near as dammit to the N10 anyway?
Near as dammit: yes.
Question would be, would the replaceable NiMH battery and longer battery life be relevant to your useage, otherwise I would prefer the LiIon battery in the N10.
Secondly, do you prefer the appearance of one over the other, considering the N10 is a little smaller.
I also like the little control stick on the N10: you can operate it blindfolded. I rarely use the remote.
Otherwise, functionally, near as dammit and you could save that 27 pounds.
Guest Anonymous
Thanks for the advice.
I'll be getting a MD player in a couple of weeks and I'll just have to decide how wealthy I'm feeling then! Perhaps I'll toss a coin - heads N10, tails N910!
Guest Anonymous
I also am after a Net minidisc....
I am looking at the N10 and 910....
Choices choices...
It looks like I am swaying towards the N10 , but only slightly..
I am gonna get one in the next couple of days....
If you fins either the N10 or 910 at good prices, let me know please...
www.digital-point.co.uk looks the best to me so far...
But there must be others out there...
Rgds
Tyrant.
