Got N10 today, amazing unit!
RISKBREAKER
Guest Anonymous
I Bought this unit aswell, and mostly, have found it great!
One question though- Maybe you can help?
When transferring MP3's using SonicStage, it has random problems. Some transfer fine, but when it tries others it comes back with an error saying - 'Detected Errors While Transferring - An error has occurred while converting the data'
Is this a copyright thing ? It's driving me mad, so any advice would be appreciated!
Thanks,
I had some problems like that, i think sonicstage only supports
MPEG 1 Layer 3 files up to 256kbps (320 wont play, i tried it)!
Maybe you have not the correct file format!
Try to decode the music file to wave (with MpegDjgowave, freeware,
not an abd tool)and then import it, worked with the 320kbps very well =)
Hope that could help =)
