Guest Anonymous Posted June 17, 2003 Report Share Posted June 17, 2003 I would like to have a small mic mixer so I can plug in 2-3 mics to conduct some round-table type interviews for segements on my net radio show anywhere I need to meet with people (Nexus Radio - www.craniumnexus.net). I would plug this directly into the line-in jack on my Sony MZ-R900. Any suggestions?? thanks, Brandon www.craniumnexus.net Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted June 19, 2003 Report Share Posted June 19, 2003 You could use a split stereo input cable, which you could probably get from RadioShack very cheaply. I've got one with two inputs for two stereo inputs, which works very well. I don't know if you can get one for 3 inputs, but you could piggy back two together I suppose. A proper mixer with volume level controls would cost a lot more, not sure of any particular makes. I have a mono mixer, but don't use it very much. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted June 19, 2003 Report Share Posted June 19, 2003 Hi. Look at Behringers site. They have a small mixer (502 or 602 i think the number was). And they only cost about 50-60 Euro. /Magnus Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted July 2, 2003 Report Share Posted July 2, 2003 I agree that a small 6 or 8 channel Behringer would be perfect! Check out www.musiciansfriend.com, or a Guitar Center store... they'll have the best prices on something like that (I think that you could get a 6 channel for about $70). Quote Link to comment Share on other sites More sharing options...
maia Posted July 2, 2003 Report Share Posted July 2, 2003 Quote I would plug this directly into the line-in jack on my Sony MZ-R900.Hum, didn't u wanna say "Mic In" (Plug In Power)?! Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted July 16, 2003 Report Share Posted July 16, 2003 A mic mixer adds amplification to the microphone signal, and the output of the mixer should indeed be plugged into the 'line in' jack on your recording device. Quote Link to comment Share on other sites More sharing options...
