Kotarou Posted July 11, 2003 Report Share Posted July 11, 2003 I Would Like to Know if the Remote Rm-Mc11el can be used on a NetMD Mz-510, if possible witch features will be disabled/enabled? Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted August 6, 2003 Report Share Posted August 6, 2003 it can be used on N510, but the sound function will be a little bit different from that of R909, u can't adjust T&B level on ur remote. Quote Link to comment Share on other sites More sharing options...
Kotarou Posted August 6, 2003 Author Report Share Posted August 6, 2003 If I Hack the N510 and use the Rm-11el, It will be possible to use Sound Function with the remote , or Use the 6-Band Eq with the remote? Quote Link to comment Share on other sites More sharing options...
mAjEsTiC Posted August 6, 2003 Report Share Posted August 6, 2003 i'm not entirely sure on this one but i would say no...i havn't gotten my 11EL to work on my N10 properly...soo imo you're better off getting a 35ELK or a 33EL because both of these are made for the N10 models and would work well with your N510... Quote Link to comment Share on other sites More sharing options...
