Optical output from MD recorder???
Guest Anonymous
Guest Anonymous
OK so NetMD is basically duff!
i have consigned myself to obtaining the Midiman CO2 which alows me to take the DIGITAL coax RCA S/PDIF input and output of my soundcard and plug them into this box to provide me with an OPTICAL S/PDIF input and output pathways to my PC.
Basically all of the recordings from CD's (i don't have a hi-fi [student accomodation is small] i use an amp and speakers plugged into my pc) and wav files that i will make will be made optically. And recording lectures will be transferred from Digital source (*minidisc converted*) ---analog---> soundcard (*ADC converted)---> digital wav file.
this digital -> analog -> digital seem POINTLESSLY inefficient and just plain unnecessary......... My question is/are:
1. is there a MD with optical output as well as input (even if it hasn't got netMD) ?
2. is it really ABSOLUTELY impossible to transfer music digitally from MD ---(*usb*)---> PC , using any (even non sony) unit, or do you think that it will be arranged (cracked) that this will be possible.
Guest Anonymous
maia, could you explain (or link to a post, if you have already explained) in more detail.. sounds interesting (i take it you have invalidated your warenty)
