Need help with Sony MZ-N10!!
sfcheney
Hi, brand new to the forum. I just bought a MZ-N10 and installed all of the software that came with the device. I cannot record mp3's or CD's to my minidisc via the SonicStage or RealOne software. Everytime I try recording, a track is copied to the mindisc, but upon playback of the track, there is no sound and the counter hangs up on the device every 5 seconds or so (the track does not play continuously). If I eject the mindisc, and reinsert it, I get a Blankdisc error message. I can record music from an external unit, such as a CD player or stereo, but I cannot record anything through my PC. There is not a problem with the USB connection. My PC recognizes the NetMD device and when I copy a track from my PC, I can see the write status on the mindisc player itself. And I can select the file to play on the mindisc player, but after I eject the minidisc, the file appears to have been erased. Thanks for the help.
  • 1 month later...
Guest Anonymous
Wow, so now it seems that N1 and N10 have similar recording faults.
I reckon its the MD head playing up or is dirty (strange if its brand new). I cleaned my N1 thoroughly, all the contacts, the USB cradle and the lens and head and it is now working more reliably.
I'll see how it goes, wanna get 3 years use before I buy an updated model.
Guest Anonymous
I hope this is the solution:
In the directory where OpenMG is (C:Program FilesSonyOpenMG Jukebox or some thing) u have to search for: ojbsir.exe. Double click this .exe file. (Note: While running this program, u must have internet connection). After that, the program tell u to install OpenMG again. This installing again IS NOT NESSESSERY. The problem now is solved!!!!
In de map waar OpenMG staat (meestal C:Program FilesSonyOpenMG Jukebox) moet u zoeken naar het bestand: ojbsir.exe
Vervolgens moet u op dit bestand dubbelklikken (Let op: Tijdens het uitvoeren van dit programmaatje dient u met het internet verbonden te zijn) Na het uitvoeren van het bestand geeft het programma het advies OpenMG opnieuw te installeren. Dit opnieuw installeren is NIET nodig. Het probleem zou nu opgelost moeten zijn.
What does that program actually do?
When I had that problem, it was because my MD write head was relatively dirty and also I think there is a wad of dust interfering with the movement of the servo motors that drive the optical pick up and MD head.
Use of a well known brand of head cleaner should help.
If it is under guarantee I would recommending getting it fixed.
