Scrolling titles on a MZ-N707?
Guest Anonymous
Guest Anonymous
Hi all,
I hope this is the right spot to post this.. but if not, please move it to the appropriate forum! smile.gif
I was wondering if there was any way to make the MZ-N707 scroll the title of the currently playing track continuously, instead of just once when starting to play the song.
BTW, I did the 'hack' ... not sure if I'll ever use the features, but it works flawlessly smile.gif
Guest Anonymous
Unfortunately, though, I haven't bought a new remote for my N707. It's a non-LCD one. I want the display on the unit itself to scroll the title repeatedly. Right now it shows (for instance) Linkin Park - In the End. As soon as that goes by, it shows only 009 (the track number). How can I make it keep scrolling Linkin Park - In the End?
u should go into your menu system (on the unit) and that should have an option/sub-menu called DISPLAY from there choose the option "1 Remain"...that should b able to allow you to c the track title continuously scroll...(i'm using my N1 as a reference)
