does anyone know a software for Mz-r700?
vietfreak
what kind of software are you after exactly??? this unit is the MZ-R700 am i correct??? this is a recorder but does not have NetMD functionality so it did not come with any software (for NetMD transfers) if this is the type of software that you were implying...
Guest Anonymous
  Quote
Even then, no software is required, you just plug it in and it installs drivers automatically.  All the Xitel plug does is make an optical output from any computer with a usb slot.
Yes, but I just wanted to know so I could help him further with his inquiry.
Sometimes you have to set it as the output.
:wink:
  • 3 weeks later...
Sorry this is kinda off topic but I have a Sony MZ-R700 that came with the USB PC Link, I got the thing connected right but when I go to record something the sound is distorted. I checked the wave levels on my comp and the levels of the media player (winamp, windows media player) but nothing seems to be helping. Can anybody help?Thanks alot!
-alex
  • 7 months later...
